Hey @RobertLucian
Thank you very much for your testing and answer.
Here are the Firmware Logs:
GrovePi Troubleshooting Script
all_tests.sh: line 6: cd: /Troubleshooting: No such file or directory
Adding permissions to the scripts
Check space left
/dev/root 6.0G 3.7G 2.1G 65% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 463M 0 463M 0% /dev/shm
tmpfs 463M 6.4M 457M 2% /run
tmpfs 463M 0 463M 0% /sys/fs/cgroup
/dev/mmcblk0p6 63M 20M 43M 32% /boot
tmpfs 93M 0 93M 0% /run/user/109
tmpfs 93M 0 93M 0% /run/user/1000
tmpfs 93M 0 93M 0% /run/user/1001
/dev/mmcblk0p5 30M 437K 28M 2% /media/administrator/SETTINGS
Check for dependencies
git 1:2.1.4-2.1+deb8u4 install ok installed
arduino 2:1.0.5+dfsg2-4 install ok installed
minicom 2.7-1+deb8u1 install ok installed
wiringPi Not Found (ERR)
wiringPi Found
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Copyright (c) 2012-2015 Gordon Henderson
Raspberry Pi Details:
* Device tree is enabled.
*--> Raspberry Pi 3 Model B Rev 1.2
* This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 001 Device 005: ID 04b3:3025 IBM Corp. NetVista Full Width Keyboard
Bus 001 Device 004: ID 046d:c046 Logitech, Inc. RX1000 Laser Mouse
|__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
Hostname
lrasp001
Checking for Atmega chip
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00: -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
python: can't open file '/Software/Python/grove_firmware_version_check.py': [Errno 2] No such file or directory
Log has been saved to Desktop. Please copy it and send it by email or upload it on the forums
There was an error reading out the actual firmware of the ZeroPi. So i run the script separate and the Version is the following: 1.2.2
The update failed to. Here is the output:
administrator@lrasp001:~ $ sudo bash Desktop/grovepi/Firmware/firmware_update.sh
Updating the GrovePi firmware
http://www.dexterindustries.com/grovepi
Run this program:
sudo ./firmware_update.sh
Do you want to update the firmware? [y,n]y
Make sure that GrovePi is connected to Raspberry PiDesktop/grovepi/Firmware/firmware_update.sh: line 18: [: ./GrovePi/Firmware/grove_pi_firmware.hex: unary operator expected
Firmware not found
Check if firmware is there or run again
Press any key to exit
I don’t have a blue DHT Sensor. Maybe i can get hands on a GrovePI (note zero).
We’re getting closer
Thanks again!
Best Regards,
Dean
