Rotating Motor Certain Angle in a Certain Amount of Time
#1
Hi. Is there a function or way to rotate a motor 180 degrees in 6 seconds?
Thanks for your help!
#2
In Python, set the motor DPS limit using set_motor_limits, and then set the target position using set_motor_position.
Something like this:
# turn degrees
TargetDegrees = 180
# seconds to reach target
TimeToTarget = 6
# degrees per second
DegreesPerSecond = TargetDegrees / TimeToTarget
# read the starting position
StartingPosition = BP.get_motor_encoder(BP.PORT_A)
# add target rotation to starting position to get absolute target
FinalPosition = StartingPosition + TargetDegrees
# set the DPS limit
BP.set_motor_limits(BP.PORT_A, dps = DegreesPerSecond)
# set the absolute target
BP.set_motor_position(BP.PORT_A, FinalPosition)
