Iβve had my BricKuber running since early 2019. I recently had a failure of the SD card and was forced to rebuild the OS from the start. This time I used a USB SSD with the 2019.04.05_Raspbian_For_Robots_by_Dexter_Industries_Stretch.img written using Raspberry Pi Imager on an iMac. This booted OK but I had to upgrade to Buster as there was at least one failed dependency. After the upgrade and a bit of tweaking BricKuber.py eventually ran but no arm or table movement.
Read_Info.py shows:
Manufacturer : Dexter Industries
Board : BrickPi3
Serial Number : 639D9855504B5354392E314BFF0F2140
Hardware version: 3.0.0
Firmware version: 1.4.8
Battery voltage : 11.9
9v voltage : 9.309
5v voltage : 4.999
3.3v voltage : 3.338
Many thanks for your rapid reply. I burned the latest Legacy Pi OS (32bit Buster 2022-09-22) onto my 120GB SSD, booted and ran the βcurlβ operation. I had to also run βsudo pip install kociembaβ but that failed with message:
βCommand βpython setup.py egg_infoβ failed with error code 1 in /tmp/pip-install-P8V3Uq/kociemba/β
until I changed the symlink in /usr/bin/python to point to /usr/bin/python3 rather than python2.
BricKuber now runs but still no motor action with neither the grabber nor table.
Ah-ha! My bad! Problem was that I had detached the motor cables from the BrickPi3 and had consulted a photo which used different ports. Once Iβd found the right ports all was well as far as motors. Now Iβve got a problem with a wrong version of numpy for kociemba but Iβm sure that is relatively easy to cure.
The most worrisome problems often end up with easy to fix solutions! Thanks for working through this one and rebuilding the whole system from scratch. Those dependencies going away are a nightmare to deal with.
