I have recently orered a brickpi, but it does not work. It does not show any sign of life (are there supposed to be leds ?).
I’m using the battery pack with fully charged 8AA batteries (multimeter shows nearly 11V output…). This is enough to power up the RPi (I removed the micro usb power to ensure the device is running on the batteries).
The troubleshoting script returns -2. Reading other posts I assume the BrickPi is dead and needs to be replaced.
Since I’m in Europe and ordered it directly in the USA, additional taxes were charged when importing the device. Let’s make sure we avoid this with the replacement…
troubleshooting script output :
troubleshooting_script_v1
Check for dependencies
python 2.7.3-4+deb7u1 install ok installed
python-pip 1.1-3 install ok installed
git 1:1.7.10.4-1+wheezy1+rpi2 install ok installed
libi2c-dev 3.1.1+svn-1 install ok installed
python-serial 2.5-2.1 install ok installed
python-rpi.gpio 0.6.1~wheezy-1 install ok installed
i2c-tools 3.1.1+svn-1 install ok installed
python-smbus 3.1.1+svn-1 install ok installed
arduino 1:1.0.1+dfsg-7 install ok installed
minicom 2.6.1-1 install ok installed
scratch 1.4.20131203-2 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Setup for Serial for BrickPi
Clock speed Configured
Serial Port not Enabled(ERR)
Serial Port Login Already Disabled
Hardware revision
gpio version: 2.31
Raspberry Pi Details:
Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Sony
Device tree is enabled.
This Raspberry Pi supports user-level GPIO access.
Read pins
±----±----±--------±-----±–±--Pi 2—±–±-----±--------±----±----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | ALT0 | 1 | 3 || 4 | | | 5V | | |
| 3 | 9 | SCL.1 | ALT0 | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 1 | 7 || 8 | 1 | IN | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 1 | ALT0 | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | OUT | 0 | 11 || 12 | 0 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 0 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 0 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | ALT0 | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | ALT0 | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | ALT0 | 0 | 23 || 24 | 1 | OUT | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | OUT | CE1 | 11 | 7 |
| 0 | 30 | SDA.0 | IN | 1 | 27 || 28 | 1 | IN | SCL.0 | 31 | 1 |
| 5 | 21 | GPIO.21 | IN | 1 | 29 || 30 | | | 0v | | |
| 6 | 22 | GPIO.22 | IN | 1 | 31 || 32 | 0 | IN | GPIO.26 | 26 | 12 |
| 13 | 23 | GPIO.23 | IN | 0 | 33 || 34 | | | 0v | | |
| 19 | 24 | GPIO.24 | IN | 0 | 35 || 36 | 0 | IN | GPIO.27 | 27 | 16 |
| 26 | 25 | GPIO.25 | IN | 0 | 37 || 38 | 0 | IN | GPIO.28 | 28 | 20 |
| | | 0v | | | 39 || 40 | 0 | IN | GPIO.29 | 29 | 21 |
Check I2C
40: – -- – -- – -- – -- 48 – -- – -- – -- –
70: – -- – -- – -- – --
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
=USER STATS=
BrickPi Found
Arduberry Found
grovePi Found
GoPiGo Not Found
BrickPiStatus
-2
BrickPi Not Found (ERR)
