There seems to be a bit of confusion here.
DexterOS is meant for the GoPiGo and not the BrickPi. To use the BrickPi and be able to ssh into dex.local, you need to have Raspbian for Robots.
Thanks for quick respond and help.
I have downloaded Raspbian For Robots.
I’m now able to use the desktop. Still I can’t use ssh. Login problems.
Ssh does not work with Hostname: dex.local. It says that the host is valid but don’t have anything to respond to me.
I have to use the IP address. My router confirm the name dex though.
By the way I got the dexterOs following the links to the software starting from the brickPi getting started.
Is it not possible to use DexterOS with the BrickPi? If not You should state that on the download page.
Egon
depending on how your network is configured, sometimes dex.local isn’t recognized by default. If you’re running a mostly Windows environment, you could try entering dex/ in the browser URL field. If that doesn’t work, is Bonjour installed on your system?
As for getting the DexterOS download while following the BrickPi instructions, I would very much appreciate it if you could detail how you got there? Obviously there’s a spot that we think is clear but is confusing for others. I would dearly love to remove the confusion!
I got an eye opener! dex/ in my browser and the startpage show up. I have used putty to open a connection. This was unsuccessful.
I haven’t tried to connect any Lego parts yet but the OS is working.
Is the only OS Raspbian-for-robots?
I miss an explanation of the pros and cons for the 3 OS.
I don’t know anything about Cinch. What special with this OS?
Still I don’t understand why the dexterOS couldn’t work on the RPi. It loads, and it ran, but I could not connect to it?
You don’t have to answer these last questions from an newbee. I’m just wondering and I’m sure to get wiser as time goes by.
Thank You for helping.
Thank you @egonjorg
I’ve added a note next to DexterOS that it is only for GoPiGo robots. Hopefully this will help others in the future.
Very kind of you to take the time to write it all out!
For the BrickPi3, the only OS is Raspbian for Robots, or its naked version Raspbian (but then you have to install the BrickPi libraries manually)
Cinch is/was a version where you could connect directly to your Pi without having to set it up on your local WiFi. It hasn’t been updated in a bit because most of the people who needed it are now using DexterOS. However Cinch could also be used for BrickPi.
DexterOS only works with the GoPiGo. It only comes with the GoPiGo libraries and is tightly coupled with that robot.
Thank You. Everything is working now.
One last question in this session:
Next step for me is programming the BrickPi in Python.
I have studied some of the examples and the projects codes.
Where can I find tutorials for writing Python code for the BrickPi3?
Egon
