I was trying to install the brickpi3 python module in a python virtual environment. I created the the environment with virtualenv env --python=python3
I then ran the install.sh script and even tried running the setup.py script. It does not import. Yes I ran this all with the environment activated and also rebooted.
Anyone have any ideas?
Hi @graykevinb,
I was able to import brickpi3
module with Python 2
and Python 3
within a virtualenv
environment.
Here’s what I’ve been doing:
I cd
-ed to ~/Desktop
where the user has rw
permissions.
Created a virtual environment with the virtualenv env --python=python3
command.
Activated the env
environment with source env/bin/activate
Created another folder on the Desktop
called env-test
, where than I cd
-ed to it.
git clone https://github.com/DexterInd/BrickPi3.git
- we need the user to have rw
access to it, otherwise, pip freeze
won’t show up our package.
cd
-ed to ~/Desktop/env-test/BrickPi3/Software/Python
Run the following commands in this order:
python setup.py clean
- removes the old build (if there’s one)
python setup.py build
- creates a new build
python setup.py install
- installs the current build
Install spidev
package with pip install spidev
Type python
and try to import the brickpi3
module - it’s going to work.
If there are any other questions, Kevin, please tell us here.
It worked! Big thanks! I did things a bit differently. I used python3 and did it in the home folder.
Hi @graykevinb,
I’m glad it worked for you.
I’m now closing the thread.
