[SOLVED] No SPI response (stacking two BrickPis)
Hello Folks,
I have a setup where I stacked two BrickPi3 on top on my RaspberryPi 3, now the problem is when I try to give the BPs their adresses, the console prompts " No SPI response"
Even when I use only one BP, the assignation of the adresses doens’t work and it prompts me the same error.
Anybody else experienced this ?
Firmware on both of them is 1.4.6
Thanks in advance,
Leroy
Hey there,
I swapped one of the BrickPis with another one and now it works :slight_smile:
problem solved
Hi @lofriedr,
Even though you figured this out, but for the sake of other readers or even for you, here’s a post on setting different addresses for the BrickPi:
I’m going to put a timer on this thread now.
This topic was automatically closed after 44 hours. New replies are no longer allowed.
