Hi, I’m on Raspberry Jessie.
My Pi boots normally without the Grove shield plugged in.
However, when plugged in, the boot only reaches the screen with 4 raspberries.
Is there a black foam attached to the GrovePi's header pins?
When you ran sudo curl ... command, did you have the GrovePi attached to your Raspberry Pi? Did this issue appear only after running the former command?
I don’t think there’s a correlation between the kernel version and the fact that your Pi doesn’t boot - just yet.
Also, the command necessary to install the GrovePi should look like:
Hi Robert,
Thanks.
No black foam attached.
I ran the command (curl -kL dexterindustries.com/update_grovepi | sudo bash) without the Grove attached.
I don’t know if there is an issue with GrovePi attached and command unrun as I didn’t try that.
