[SOLVED] Support for mindsensors NXTMMX-v2
Can this motor multiplexer
http://www.mindsensors.com/ev3-and-nxt/21-multiplexer-for-nxtev3-motors?search_query=motor+multiplexer&results=2
work with a BrickPi3?
Or otherwise, what is the best way to add a 5th ev3/nxt motor?
The NXTMMX is not supported, although if you’re comfortable with writing I2C drivers for it, I’m sure it could be made to work.
However, I would recommend using a second BrickPi3. Check out this thread regarding stacking BrickPi3. If you stack two BrickPi3 boards, you could use up to 8 EV3/NXT motors and 8 EV3/NXT sensors.
I thought as much. Cheers.
This topic was automatically closed after 2 days. New replies are no longer allowed.
