Continuing the discussion from Specs of brickPi3 H-bridges?:
Quote by Matt:
For 4 ports (2 channels on each of the 2 drivers) simultaneously at 100% pwm, the datasheet says 0.9A per channel at 25℃ ambient temperature. You can look at the chart on page 6 of the datasheet for the maximum current for 1 and 2 channels at different PWM duty cycles. For reference, motor ports MA and MB share a motor driver (each uses 1 channel), and MC and MD share a motor driver (each uses 1 channel).
To summarize, the BrickPi3 is designed to run Lego Minstorms motors, and I advise against using it with other motors.
I have o disagree, Page 6 does not show a chart about max peak current, just about continuous current:
So which or where are the required data?
