Using sesors and motors at the same time
When ever I try to use the Utrasonic Sensor at the same time as the Motors it says
Connected to Scratch successfully
Setting up Sensors Done
Severce Started
  File "BrickPiScratch.py"/ line 128, in <module>
    thread1.start()
  File "/usr/lib/python2.7/threading.py", line 489, in start
    raise RuntimeError("threads can only be started once")
RuntimeError: threads can only be started once
I don’t know what is wrong
We are having an identical issue. Have tried everything we can think of. Please HELP!
I didn’t find a fix to this so I learned python and coded python. You can learn it easily at codecademy.com . Free and Easy to use for any age.
Thanks for the response. May have to go that way, which is a bit frustrating as the project was something my 6 year old son and I were doing together. Still, as I say, thanks for the update.
Hey folks,
We’ve been working on full re-work of the Scratch interface for the BrickP. Information on it is in the latest issue of MagPi: http://www.themagpi.com/issue/issue-23/
I think this problem should be solved. The writeup is really great and walks you through setup and use.
@kimandjack3 Welcome to the Dexter Industries / Modular Robotics User Forum.
Your post on this thread appears to offer help, but the post is from seven years ago.
Are you a new user of one of the Dexter Industries or Modular Robotics products?
