What can Pi5 GoPiGo3 Expect?
If you solve the at least 5v 3A or 5A desired power issue, and the stacking difficulty with a Pi5 fan/cooler:
MY Pi5 PERFORMANCE TESTS
Raspberry Pi5 8GB mounted in official Pi5 case with fan
  • Python3 floating point addition 0.000973ms - 3.5x faster than Pi4
  • Python3 integer addition 0.000657ms - 3.8x faster than Pi4
  • Four CPU Stress for 5 minutes: No throttling, 70.3C temp
  • ROS 2 (Docker containerized) executes 3x faster than Pi4
MY HUMBLE DAVE Pi4 2GB PERFORMANCE TESTS
Raspberry Pi4 2GB sandwiched to GoPiGo3, small heatsink, no fan
  • Python3 floating point addition 0.000280ms - 3.5x slower than Pi5
  • Python3 integer addition 0.000174ms - 3.8x slower than Pi5
    1:30 Temperature throttling
    2:30 Voltage throttling occurred, temperature throttled
    Max temp: 85.2C End temp: 83.7C
What heat sink are you using that fits between the Raspi 4 and the reg GoPiGo3 board? Also, might it be possible to fit a small heat with fan - not sure if this is too big but something like the following?
“Old GoPiGo3” Carl has 5mm heatsink:
“New GoPiGo3” with cap moved can support a larger heatsink even than I have in Dave:
This is @Jimrh solution to putting a fan on the GoPiGo3 - I think his was an “Old GoPiGo3”, so it might go easier with a “New GoPiGo3”
Here is the Pi5 cooler:
Edited former post with cooler info
Yup.
I had to remove and reposition the large cap to match the new rev GPG boards.  However the large inductor for the switching supply is still in the way.  I had to trim a few millimeters off the top edges of the fan blades for it to fit and work.
I have a new rev GPG board (for Charline) that I plan to experiment with, using things like the 8gig Pi-4, a first generation Jetson Nano, and the Pi-5.
We will see.
It would be absolutely bodacious if I can install the GPG-3 libraries on the Nano!  Maybe even ROS? (!!)
