How to change the default python in Raspbian for Robots Buster?
Greetings!
Re:
My postings on beating up GPGOS located at:
I am trying to run the same “stress test”, (build a wheel for wxPython 4.1.1), on Raspbian for Robots Buster, but ran into an ANNOYING problem:
The default Python in R4R is (gasp!) Python 2!
Trying to build a wheel-file for wxPython 4-dot-anything is doomed because it does not support Python 2 anymore.
This leads to the Musical Question:  (drum roll. . . . .)
How do I change the default Python while in R4R?
I don’t think that is advisable.
When I was building the imu4gopigo3 packages I had to do:
* Remove any old package, and Compile the package
rm dist/*.whl
python3 setup.py bdist_wheel
and for python2:
sudo rm dist/*.whl
sudo python2.7 setup.py bdist_wheel
Perhaps the build script will need to specify python3 everywhere it just has python?
