This isn’t going to be possible. You cannot control a sensor directly through the GPIO’s of the Pi; rather the BrickPi sends a message to the sensors over the serial line and to the microcontroller on the BrickPi. The BrickPi controls the LEGO / EV3 / NXT sensors.
To read sensors attached to the BrickPi, you can see our examples on github for each sensor?
Hello, i dont want to control a sensor through the gpio. This is just an example. Is it possible to use interrupts? I know there is a command *waitForChange() * But i dont understand the docs really. Where can i read an example to use interrupts? I cant find it in the sensor or project examples. I think its not a good solution to ask a touch sensor every .1 seconds. It is better to ask a sensor only when it change its value. Or am i wrong?
I don’t think that there is any way by which you can use interrupts directly. Though you can make a something like this to find the change of state:
from BrickPi import * #import BrickPi.py file to use BrickPi operations
BrickPiSetup() # setup the serial port for communication
BrickPi.SensorType[PORT_4] = TYPE_SENSOR_TOUCH #Set the type of sensor at PORT_1
last_state=-1
current_state=0
def check_touch():
global last_state,current_state
result = BrickPiUpdateValues() # Ask BrickPi to update values for sensors/motors
if not result :
current_state=BrickPi.Sensor[PORT_4] #BrickPi.Sensor[PORT] stores the value obtained from sensor
if current_state<>last_state:
last_state=current_state
return current_state
else:
return -1
st=check_touch()
if st<>-1:
print "state changed to",st
time.sleep(.01) # sleep for 10 ms
You can use this with threads if you want even better response.
